CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Cavitation 2D geometry
24 REPLIES 24
Message 1 of 25
667 Views, 24 Replies
Hi everyone,
I have a problem with a 2D geometry where get static pressures of -95000 [Pa], and with the cavitation module enabled, when i look at cavitation there is 0%, although i have changed in phase options of the water the vapor pressure to 50000 [Pa] (i know thats not real, but it was to check if cavitation module was working).
Could anyone help me?
24 REPLIES 24
Message 21 of 25
srhusain
in reply to: Jon.Wilde
You might also suppress the outer-most solid and select the smallest edge of the fluid boundary to apply the pressure BC. Note that the outer solid is not essential to the fluid flow problem.
Message 22 of 25
in reply to: srhusain
thanks for all, i am going to try to do that thing, and i will say you if the problem disappears
Message 23 of 25
srhusain
Attached is a modified support file that you can try. The attached picture shows some cavitation near the bottom of the model.
Message 24 of 25
magic???really thank you!!! but i dont understand why does it run... :S
Message 25 of 25
srhusain
I think the key is to use small time steps and 3 nner iterations per time step to get accurate transient simulation. Of course, the pressure boundary condition is essential for stability. Here, I am using 0.5 degrees per time step in order to ensure that the rotor mesh faces (edges) do not skip its counterparts on the stator side as skipping would cause a loss of information transfer between rotot and stator.
