I cannot stop one analysis. When I hit the stop button, it greys out and does nothing. In this past when this happened, I used to close the cfdst file, stop and restart the server manager .exe file saved in C: drive where the program is installed. I did the same thing today but it didn't work.
I sometimes used to clear up the analyze folder. I coundn't find that analyze folder either. Is that log saved somewhere else these days?
Solved by OmkarJ. Go to Solution.
Are you running locally or using Sim 360?
You may need to start from a fresh CFZ file as it sounds as though the project may be corrupt.
Kind regards,
Jon
If I may add here, you can find the Analyze folder in SimCFDServer dialogue box. If I remember correctly it is the second path from the top in that window. I generally do it in following sequence. Stop the simulation, close it, Open SimCFDServer and stop it, clear Analyze folder, start the server and open the simulation.
