CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Cannot stop an analysis. How to clear up the analyze folder?
2 REPLIES 2
kabindrabhattarai
532 Views, 2 Replies
I cannot stop one analysis. When I hit the stop button, it greys out and does nothing. In this past when this happened, I used to close the cfdst file, stop and restart the server manager .exe file saved in C: drive where the program is installed. I did the same thing today but it didn't work.
I sometimes used to clear up the analyze folder. I coundn't find that analyze folder either. Is that log saved somewhere else these days?
2 REPLIES 2
Are you running locally or using Sim 360?
You may need to start from a fresh CFZ file as it sounds as though the project may be corrupt.
Kind regards,
Jon
OmkarJ
in reply to: kabindrabhattarai
If I may add here, you can find the Analyze folder in SimCFDServer dialogue box. If I remember correctly it is the second path from the top in that window. I generally do it in following sequence. Stop the simulation, close it, Open SimCFDServer and stop it, clear Analyze folder, start the server and open the simulation.
