Discussion Groups
Simulation CFD
Active Member
0 Kudos
Cannot refine the grid size in "save table"
129 Views, 2 Replies
01-28-2013 12:10 PM
The grid spacing option does not work in the Plane Control page to save daat as table. any suggestion what to do?
P.S. snapshot attached.
Distinguished Contributor
34 Kudos
Re: Cannot refine the grid size in "save table"
01-28-2013 11:52 PM in reply to: adesk360
Try enabling the Vector Settings to show any vector results. After that, you should be able to adjust the grid spacing slider bar.
Regards
Ilyas
Product Support
54 Kudos
02-01-2013 01:03 PM in reply to: ilyas
To be able to adjust the Grid Spacing, you either need to have Vectors on, or set the Appearance to Shaded Grid or Outline Grid.
In your image your Appearance was set to Shaded, so the Grid Spacing had nothing to control and as such is greyed out.
