The grid spacing option does not work in the Plane Control page to save daat as table. any suggestion what to do?
P.S. snapshot attached.
Solved by apolo_vanderberg. Go to Solution.
Try enabling the Vector Settings to show any vector results. After that, you should be able to adjust the grid spacing slider bar.
Regards
Ilyas
To be able to adjust the Grid Spacing, you either need to have Vectors on, or set the Appearance to Shaded Grid or Outline Grid.
In your image your Appearance was set to Shaded, so the Grid Spacing had nothing to control and as such is greyed out.
