Does anyone know how to extend the "Points" window so the full "Name" description is visiable?
Thanks, Dan
Solved by Royce_adsk. Go to Solution.
Hi Dan,
If you cannot do so from the bottom corner of the window, how about sliding just the name column over to expand it?
Jon,
The window is not allowing me to grab it's lower corner to expand the window, nor is it allowing me to grab the edge of any column to slide the column over.
Regards, Dan
