Discussion Groups
Simulation CFD
24 Kudos
Can the "Points" window be expanded?
98 Views, 4 Replies
06-07-2013 07:49 AM
Does anyone know how to extend the "Points" window so the full "Name" description is visiable?
Thanks, Dan
Product Support
149 Kudos
Re: Can the "Points" window be expanded?
06-10-2013 02:13 AM in reply to: dkusmer
Hi Dan,
If you cannot do so from the bottom corner of the window, how about sliding just the name column over to expand it?
Jon Wilde
24 Kudos
06-10-2013 04:34 AM in reply to: wildej
Jon,
The window is not allowing me to grab it's lower corner to expand the window, nor is it allowing me to grab the edge of any column to slide the column over.
Regards, Dan
Product Support
232 Kudos
06-10-2013 09:47 AM in reply to: dkusmer
Hi Dan,
Those are fixed windows in the program. I would suggest that you add an idea to the idea station to get this changed.
http://forums.autodesk.com/t5/Simulation-CFD-IdeaStation/idb-p/82
Thanks!
Royce
Royce Abel
24 Kudos
06-10-2013 01:47 PM in reply to: Royce_adsk
Royce,
Thanks, I'll do that.
Regards, Dan
