CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Can't launch CFD 2015 by Inventor
9 REPLIES 9
Message 1 of 10
710 Views, 9 Replies
First of all. I sorry for  my English is very poor .
I use CFD 2015 64 bit and Inventor 2015
I have problem to Launch Active model CFD in Autodesk Inventor .
1. I can't change Study name in Design study manager .
2. In Panel update design study . I can't click update floder .
3. When I click Launch in dialog box . I not have model in CFD.
but I can use New in CFD program for run model .
Thank you!!
9 REPLIES 9
Message 2 of 10
ryan.arnaudin
hi bobaa, can you please post a screenshot or shot video of the issue?
Note, to update a design study you must have an existing design study to update. Select at the design study level in the list to open the existing study or add the geometry to a new design in the study. Select at the design level in the list to update geometry for that existing design in the study.
Message 3 of 10
in reply to: ryan.arnaudin
Message 4 of 10
Royce_adsk
That is a very unique issue.  The first thing I would suggest is to close everything down and run the following program.
To run this program correctly right click on chose 'Run as Administrator'
C:\Program Files\Autodesk\Simulation CFD 2015\SimCFDConfig.exe
Lets see if that fixes the issue.
Thanks!
Royce.Abel
Technical Support Manager
Message 5 of 10
in reply to: Royce_adsk
Thank you Royce_adsk. This Pic after I'm right click and  chose Run as Administrator in SimCFDConfig.exe file.
But ,It's still the same
Message 6 of 10
Royce_adsk
Is this Windows 8?
Seems to me to be partly a read/write issue and maybe graphics card/driver?.
What graphics card do you have?
Have you tried to update the driver to the most recent avaiable?
What virus scanner do you have installed?
Royce.Abel
Message 7 of 10
Yes! window 8
Message 8 of 10
NVIDIA GeForce GT 540M 2GB  . It's driver is up to date
And I use window defender .
Message 9 of 10
tong6
Can you share the screen of CAD model folder( where the inventor model exists ) and the %temp% folder? I suspect some temperory files are not generated for some permission issue.
Message 10 of 10
ryan.arnaudin
in reply to: tong6
You also may try deleting the file “design_studies.info” in the following directory:
C:\Users\[user_name]\AppData\Local\Autodesk\Simulation CFD 2015
