Discussion Groups
Simulation CFD
OmkarJ
Can't apply fully developed flow
277 Views, 8 Replies
12-05-2012 01:09 AM
Ok, this is painfully hilarious.  I have a perfectly circular inlet but when I try to apply a fully developed flow condition (volume flow), it doesn't let me apply. When I untick the fully developed setting , only then I can apply the boundary condition. Going back to CAD (Inventor 2012), I can measure the diameter of that inlet boundary, meaning that CAD confirms its circularity, which is the requirement of fully developed flow!
Any thoughts?
OJ
Please use plain text.
OmkarJ
Re: Can't apply fully developed flow
12-07-2012 12:54 AM in reply to: OmkarJ
Someone, please?
Valued Contributor
marco.mueller
12-11-2012 06:56 AM in reply to: OmkarJ
Maybe the edge is split? Or not perfectly flat?
OmkarJ
12-11-2012 06:59 AM in reply to: marco.mueller
Thanks, at least someone heard! But how to know if the edge is split? The CAD software confirms the circularity as I can measure the diameter. And Geometry Tools in SimCFD doesn't highlight any concern.
Regards
OJ
Valued Contributor
marco.mueller
12-11-2012 07:01 AM in reply to: OmkarJ
go to edge selection method and pick the edge. Then you'll see if it is just one or more...
New Member
daniel.s.christmann
12-19-2012 05:56 AM in reply to: OmkarJ
Hallo,
I have the same Problem OmkarJ described. I can't apply fully developed flow as boundary conditon.
I'm using a Student Version of Simulation CFX 2013.
Is this probably the reason why I'm not able to use this function?
Daniel
OmkarJ
01-07-2013 01:49 AM in reply to: OmkarJ
Well it's just one edge! I had not been able to apply this boundary condition since ages!
Regards
OJ
Distinguished Contributor
ilyas
01-07-2013 07:31 PM in reply to: OmkarJ
I suggest you try to export your CAD file to another format, open it in Simulation CFD and apply the fully developed BC.
I tried directly opening my CAD file in Simulation CFD using the Invertor Add-in and faced the same issue when applying the fully developed velocity BC (cannot press Apply on the quickedit dialogue box). For me, the problem only happens for circular cross sections, I experimented with a square cross section and it works fine(as far as applying the BC). For circular cross sections, I exported my CAD as parasolid text and was successful in applying the fully developed velocity BC. I think there might be a problem with the Inventor translations for circular profiles. The problem did not exist for the 2014 Beta version though.
Regards
Ilyas
OmkarJ
01-08-2013 12:59 AM in reply to: ilyas
I have lodged the case with subscription center. I will update this thread with any remedy suggested.
OJ
