CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Can not see/open .step-files in Simulation CFD
5 REPLIES 5
1096 Views, 5 Replies
i have a rather strange problem with Simulation CFD. I can not see any .step or .stp files I created with FreeCAD and want to load in Sim CFD 2015.
I already tried to re-install SimCFD and my Windows several times. I don't get any license errors or anything.
Can someone help?
5 REPLIES 5
Jon.Wilde
Might you be able to post one of these files for us to test?
Are you going to 'new' within CFD to import the file?
Jon
in reply to: Jon.Wilde
Hi Jon,
thanks for your quick reply. I kinda solved the problem by loading the .step files into Inventor and saving it as a .sat file there. Then again loading this into Sim CFD which worked for me. I could'nt see the .step files but i can see .sat files, so i'm working with that for now.
Cheers,
Clemens
pmenzies10
Hi Clemens,
Always a good choice when CAD is doing the unexpected.   But I would like to ask - Are you on the latest build of Simulation CFD 2015?  You can check by use the Help_About pull down menu.  It should show version 15.2.  In this version, your model loads with 17 parts.  It looks like it will be a fun analysis to run.
Peggy
in reply to: pmenzies10
Hey Peggy,
thanks for your reply. 🙂 I checked the version number and actually it gives me build 15.1. Do you know if i can upgrade it via service pack?
-Clemens
Jon.Wilde
