Discussion Groups
Simulation CFD
New Member
reuther.marcel
Calculate Circumferential Velocity and show result on a plane
559 Views, 4 Replies
05-08-2013 01:26 AM
Hey community,
I'm new here and hope you can help me. I've got a tube flow with flow direction to the x-axis. Because of swirl I also want to calculate the resulting circumferential velocity. At the "results" I can see the velocity in y-direction and in z-direction on a plane. I just want to calculate the resulting circumferential velocity. Is this somehow possible?
Thank you in adavance.
Regards
MR
Please use plain text.
OmkarJ
Re: Calculate Circumferential Velocity and show result on a plane
05-13-2013 06:05 AM in reply to: reuther.marcel
How about finding the individual Y and Z velocities and take the vector addition of the two?
OJ
New Member
reuther.marcel
05-13-2013 02:11 PM in reply to: OmkarJ
Thank you for your response. Can you explain me how can I calculate the addition of two vectors?
Regards
MR
OmkarJ
05-15-2013 08:46 AM in reply to: reuther.marcel
I hope by circumferential, you meant tangential (ie in YZ plane). If you want to calculoate the velocity at any point, just use the normal vector addition rules and find the angle. But if you want to see the contours of the tangential velocities, then you need to define a custom variable and I think SimCFD does not allow it.
OJ
Member
cheidusc
03-14-2014 06:05 AM in reply to: OmkarJ
I am also interested in your solution. I have calculated the vector in the YZ Plane. But how can I calculate the tangential velocity?
