Discussion Groups
Simulation CFD
Active Member
0 Kudos
Average fluid velocity in a vloume
402 Views, 3 Replies
04-19-2012 07:23 AM
Is there a good way to determine the average velocity of a fluid in a volume?
Product Support
53 Kudos
Re: Average fluid velocity in a vloume
04-19-2012 07:29 AM in reply to: TitusCFD
Average Velocity in a random volume out of your domain. Or the average velocity across the domain itself?
Active Member
0 Kudos
04-19-2012 07:59 AM in reply to: apolo.vanderberg
Im not sure about the domain terminology. But, I guess it would be in the domain. I have attached a quick sketch of the model I am working with. I am trying to determine the average air velocity in the room.
Product Support
53 Kudos
04-19-2012 11:38 AM in reply to: TitusCFD
TitusCFD
     The Summary file will give you the Statistics for velocity through the entire domain (in other words the whole model).
What I was referring to with the previous question was if you wanted data for the whole model or perhaps a small corner that you were interested in.
For a more local average you can use Cutplanes (and its ability to save out csv data), or XY plots.
Apolo
