I'm doing a scalar mixing problem and I would like to get the data from the summary file every X seconds over a longer time span. Is there a way to automate the saving of the summary file data so that I don't have to manually stop & restart my study after each segment X? This could become a very tedious process otherwise.
Solved by apolo_vanderberg. Go to Solution.
I sincerely hope there is a convenient way too. The useful data I need is only saved in the summary file, as far as I know. I'm not sure I have the time to delve into writing a script, nor do I have much experience running them 😞
If what you are looking for is Summary file information, under the Solve dialog you can specify a Save Interval for the Summary information such that you would have a rolling history for your inlets/outlets across the run.
If you can elaborate a little more we might be able to point in a better direction as well.
