CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Autodesk Simulation CFD 2014 Performance on a Dell T7600 vs ASUS g55v
3 REPLIES 3
kaiwei
750 Views, 3 Replies
We recently tried running a simulation with the same CAD model and setup between a Dell Precision T7600 (workstation) and an ASUS g55vw (gaming laptop). For a comparison, we started the simulations file at the same time. After 30 mins, the Dell T7600 was at 13 iterations vs the ASUS g55vw at 75 iterations.
1. The workstation took over 10 mins to prepare model for solving. It gets stuck at volume meshing for a long time. The gaming laptop finished it in a few minutes.
2. The workstation takes over another 10 mins for the first iteration, while the gaming laptop starts in a few minutes.
Alternatively, the ASUS g55vw takes only less than 5 mins to start the simulation.
We have updated the NVIDIA graphic card drivers to the latest ones but the setup is still slow.
Is there a reason for the discrepancy in the performance?
3 REPLIES 3
Jon.Wilde
in reply to: kaiwei
What are the other specs of these machines?
CPU and RAM?
apolo_vanderberg
in reply to: kaiwei
KaiWei,
As Jon mentioned can you list the specifics of these machines as a T7600 can have a range of CPU's
What CPU (# physical cores) / RAM / harddrive is in each of the two machines?
Did you use the same file between the two or did you manually try to make a similar analysis?
Typically I would run the model on Machine A and then take the support sharefile to Machine B and run it there.
If you look at the Summary file we will detail the timing of each of the segments for performance tracking
Input Time
Analysis Time
Output Time
Where you should see the desktop (depending on the specs) excel would be in the Analysis Time.
kaiwei
in reply to: apolo_vanderberg
Processor Intel® Core™ i7 3630QM Processor Intel® Core™ i7 3610QM Processor Intel® Core™ i5 3230M /3210M Processor Operating System Windows 8 Pro Windows 8 Windows 7 Ultimate Windows 7 Professional Windows 7 Home Premium Windows 7 Home Basic Chipset Intel® HM77 Chipset Memory DDR3 1600 MHz SDRAM, 4 x SO-DIMM socket for expansion up to 32 GB SDRAM *1 Display 15.6" HD (1366x768)/HD 3D (1366x768 120Hz)/Full HD (1920x1080)/Wide View Angle LED Backlight Non-Glare LCD Panel Graphic NVIDIA® GeForce® GTX 660M with 2GB GDDR5 VRAM Storage 1TB 5400 750GB 5400/7200 500GB 5400/7200 128GB SSD 750GB 7200 SSH Optical Drive Blu-Ray DVD Combo Super-Multi DVD Blue-ray reader Card Reader 3 -in-1 card reader ( SD/ MS/ MMC) Camera HD Web Camera Networking Integrated 802.11 b/g/n or 802.11ac Built-in Bluetooth™ V4.0 (Optional) 10/100/1000 Base T Interface 1 x Microphone-in jack 1 x Headphone-out jack 1 x VGA port/Mini D-sub 15-pin for external monitor 4 x USB 3.0 port(s) 1 x RJ45 LAN Jack for LAN insert 1 x HDMI 1 x SPIDIF speaker out 1 x mini Display Port 1x Thunderbolt port (Optional) Audio Built-in Speakers And Microphone Built-in subwoofer Battery 8Cells 5200 mAh 74 Whrs Power Adapter Output : 19 V DC, A, W Input : 100 -240 V AC, 50/60 Hz universal Dimensions 384 x 299 x 20 ~51 mm (WxDxH) Weight 3.8 kg (with 8 cell battery) Security Kensington lock Note 1* Intel® Core™ i5 SKUs has 2 memory slots Intel® Core™ i7 SKUs has 4 memory slots •G Series notebooks with Thunderbolt are only compatible with devices carrying Intel Thunderbolt certification for PC
