Dear sir
I'm a mechanical engeneering student and i'm now working in my final project.
I wonder if you can help me with this matter.
I've just started using CFD simulation software and my knowledge in fluid dynamics is basic.
I followed autodesk video tutorials but in the end i got an error.
If it's possible i would like to be informed about what i'm doing wrong.
Thank you
Hi
You need to model the air. Use the guide here.
Note the use of Height Of Fluid.
Also, do not suppress the moving part from the mesh. Or use a rotating region, which is probably a better approach.
Kind reagrds,
Jon
By the way, I am assuming you want to model that free surface, which means you will need CFD 2015?
Otherwise I do not think you can run a model of this type.
That depends entirely on your machine, it would not be a fast analysis though.
