Greetings!
I am running a simulation on Autodesk CFD 2013 on a race car model. I am struggling to assign material on the tyres. Since i did not manage to find rubber in the material list ( for which i am quite surprised) i would like to ask you for a piece of advice, what should i do? Probably create my own material?
Thank you in advance!
Hello again!
It seems that Silicon Rubber should be the needed material. It is a default material, so the problem is solved. 🙂
