CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
API Documentation is missing
14 REPLIES 14
Message 1 of 15
mike.h
854 Views, 14 Replies
Hi everyone,
it seems as if the API documentation is only partly available in the \Help folder. In the Autodesk online help it says:
"The API language reference is included in a separate documentation library included with the installation. To access it, navigate to the Help\API-Documentation sub-folder of your Autodesk Simulation CFD installation, and double click on index.html."
However, there is no index.html in that folder. I really need it for creating python scripts, can someone tell me how to add it to the installation?
Thanks in advance!
14 REPLIES 14
Message 2 of 15
Royce_adsk
in reply to: mike.h
You don't see this file in your 2013 installation?
C:\Program Files\Autodesk\Simulation CFD 2013\Help\API Documentation\HTML\index.html
-Royce
Royce.Abel
Technical Support Manager
Message 3 of 15
mike.h
in reply to: mike.h
I have made a screenshot of the Folder "\API Documentation\HTML"
Message 4 of 15
Royce_adsk
in reply to: mike.h
It looks to me that you have a corrupt install. I would uninstall and try again. There should be 214 files in there.
-Royce
Royce.Abel
Message 5 of 15
mike.h
in reply to: mike.h
I have already tried that, the problem remains...
Message 6 of 15
Royce_adsk
in reply to: mike.h
When you installed did you right click and pick 'run as administrator'?
Sometimes that helps.
-Royce
Royce.Abel
Message 7 of 15
mike.h
in reply to: Royce_adsk
I reinstalled it with right-click "run as administrator" and still no change. Is it possible do address the Help folder on the Installation Disc directly?
Message 8 of 15
marco.mueller
in reply to: mike.h
same for me. Seems to happen for the German version.
Dipl.-Ing. (FH) Marco Müller
Application Engineer Digital Simulation
Mensch und Maschine Deutschland GmbH
www.mum.de/cfd
Message 9 of 15
mike.h
in reply to: mike.h
if it is so, would you be so kind and provide a download link, i would gladly appreciate it.
regards,
mike
Message 10 of 15
mike.h
in reply to: mike.h
still no update on this?
Message 11 of 15
mike.h
in reply to: mike.h
i would like to know if somebody has found a way to solve this problem
Message 12 of 15
Royce_adsk
in reply to: mike.h
Message 13 of 15
h.schlichter
is there an API documentation for CFD 2018 available? The most actual doc I found is for CFD 2016.
Regards
H. Schlichter
Message 14 of 15
Royce,
Your link did not work.
Is there any API documentation later than 2016?
Mark
Message 15 of 15
This link should work:
https://knowledge.autodesk.com/support/cfd/downloads/caas/downloads/content/autodesk-cfd-2016-python...
As far as I know there is no newer doc.
H. Schlichter
