I can't seem to stop a transient simulation by clicking stop via the solve interface or right clicking and stopping via the solution monitor. I see the "Stop button selected. The analysis will stop at the end of the current iteration." Then it just marches on to the next iteration. Ideas?
Solved by Royce_adsk. Go to Solution.
Are you using the desktop or Flex/360 version of the product?
I am using the 2015 desktop version. I have been running a transient analysis with 1 second time steps and 5-10 inner iterations. Does it have to finish an entire time step before stoping or is an inner iteration a valid stopping point as well?
It should stop after all the inner iterations finish for that specific timestep. Is that what you are seeing?
