CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Analysis has stopped because the Solver has exited Unexpectedly
22 REPLIES 22
Message 1 of 23
allous5
1702 Views, 22 Replies
hello there,
I have Autodesk Simulation CFD 2013 and the software is running normally. The issue arises every time I tried to generate the mesh, the following error message pops out: Error Message—Analysis has stopped because the Solver has exited Unexpectedly I have tried all options  as mentioned in the following link
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17496447&linkID=18154757
such as: solving the memory problems and increasing the
required RAM (MaxRadMatrixSize 6GB) coarsen the mesh simplifying the geometry and BCs as well. Even with a simple problem such as flow inside a single pipe,  the same issue happened. (take a look at the attached file)
please let me know what the problem could be and how to resolve it?
thank you very much
regards,
EJ
22 REPLIES 22
Message 21 of 23
Jon.Wilde
in reply to: fathur.rozi
Hi Fathur,
As this is a licencing issue, it would be best for you to post a question in the licencing forum here: http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24.
I hope that is OK.
I am reluctant just to move this thread over as so many of the other comments were not a licencing problem.
Also, check your licpath.lic file (this is not your licence but a pointer to it). Make sure that the first line reads correctly as per the post here http://forums.autodesk.com/t5/Simulation-CFD/Can-t-access-the-License-Server-from-the-Interface/m-p/...
Kind regards,
Jon
Message 22 of 23
fathur.rozi
in reply to: Jon.Wilde
I really apreciate your answer,
Thank you,
Fathur
Message 23 of 23
abdullah.tareq
in reply to: allous5
hello 🙂
i have the same problem, i'm using cfd 2014 and it's running from my local drive, i really need your help,
plesae..
