Discussion Groups
Simulation CFD
Member
0 Kudos
Analysis has stopped because the Solver has exited Unexpectedly
830 Views, 22 Replies
10-23-2013 04:55 AM
hello there,
I have Autodesk Simulation CFD 2013 and the software is running normally. The issue arises every time I tried to generate the mesh, the following error message pops out: Error Message—Analysis has stopped because the Solver has exited Unexpectedly I have tried all options  as mentioned in the following link
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17496447&linkID=18154757
such as: solving the memory problems and increasing the
required RAM (MaxRadMatrixSize 6GB) coarsen the mesh simplifying the geometry and BCs as well. Even with a simple problem such as flow inside a single pipe,  the same issue happened. (take a look at the attached file)
please let me know what the problem could be and how to resolve it?
thank you very much
regards,
EJ
Product Support
147 Kudos
Re: Analysis has stopped because the Solver has exited Unexpectedly
10-23-2013 05:48 AM in reply to: allous5
Hi EJ,
Can you confirm that you are running this from a local harddrive?
Kind regards,
Jon
Jon Wilde
Member
0 Kudos
10-23-2013 05:58 AM in reply to: wildej
Dear John,
no, I'm running the software on a sharing network.
the main software is located on the administrator pc (on my boss pc) therefore, we are using the software on a shared network.
I tested the software on his pc, and it running perfectly.
what do you think I should do in this case??
thanks for your response.
EJ
Product Support
147 Kudos
10-23-2013 06:00 AM in reply to: allous5
By using on a shared network do you mean you have it installed locally but with the licence networked?
If that is the case, I suggest you try running the model from a local file.
Kind regards,
Jon
Jon Wilde
Member
0 Kudos
10-23-2013 06:06 AM in reply to: wildej
Yes, correct
I meant that the software is installed locally but with the license networked.
ok so then how to run the model from a local file??
can you explain please in more details
EJ
Product Support
147 Kudos
10-23-2013 06:10 AM in reply to: allous5
Hi EJ,
It is fine to use a network licence.
I mean that the project you open must be on your C drive - the cfdst or CAD you launch from must be held here. This is the likely cause.
Does that make sense?
Jon
Jon Wilde
Member
0 Kudos
10-23-2013 06:22 AM in reply to: wildej
Great
I transferred my Autodesk project and CAD model to the main C drive and now it's working and the mesh is generated :smileyhappy:
I really appreciate your help
thanks
EJ
Product Support
147 Kudos
10-23-2013 06:23 AM in reply to: allous5
Hi EJ,
Not a problem, pleased to hear it works.
Jon
Jon Wilde
0 Kudos
11-03-2013 07:05 PM in reply to: allous5
The same problem may happen to me, the process stuck when solving, I try to stop the process and I try with a new file, also stops with quequed message.
please help me
thank you verry much
Product Support
147 Kudos
11-03-2013 11:35 PM in reply to: allous5
It sounds like your first problem is that you have a model stuck in the queue. With CFD closed, open up the SimCFDserver (right click and run as admin) and then Stop/Uninstall/Reinstall the server using the available buttons. That should give you a fresh slate to start running from - the model that shows as queued might not run though, you may need to start over from the _support.CFZ that would have been created when you pressed 'Solve'
Kind regards,
Jon
Jon Wilde
