CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
air flow from one space to another space.
8 REPLIES 8
Message 1 of 9
markkolk
1008 Views, 8 Replies
How should I set the boundaries for a flow from one space to another space in a building.
here is the volume flow, a fixed data
So I will remove air from one room and take it to the other room.
I like to hear it
best regards
Mark
8 REPLIES 8
Message 2 of 9
derrek.cooper
in reply to: markkolk
Hi Mark. Assuming the rooms are connected? The easiest way is to apply a flow rate on one end (the inlet) and apply an outlet boundary condition on the other end to represent a return in the system. Easiest outlet BC is a Pressure = 0 on a surface.
If this doesn't make sense, either post an image here (if you can) or a "share" file (File>save>share file)
Derrek Cooper
Director, Inventor Products
Message 3 of 9
markkolk
The drawing is a sectional view of the building, it is a building in a building. like a box in a box.(see Attachment)
the air inlet from the floor and the air outlet in the wall.
the model is made in revit and read into CFD 2012, I have two mass placed. 1 in the inner sanctuary building and 1 in the entire building. these two overlap each other.
I want to simulate air flow between these two. under the influence of solar radiation and temperature outside.
How should I set my boundaries. what happens to the two mass which overlap and are set to air.
I like to hear it,
Sincerely,
mark
Message 4 of 9
derrek.cooper
Hi mark.. The air needs to exit or vent somewhere. Otherwise, the space would just build infinite pressure as air is added
Derrek Cooper
Message 5 of 9
markkolk
hi derek,
In order to get air out of the building, I have a hole at the bottom, and holes made ​​in each floor in the model. in this way, the air can leave the building.
but how do I set my boundaries for this, just the flow or by  pressure and flow.
best regards
Mark
Message 6 of 9
derrek.cooper
You only want one flow/pressure bc on each. Flow rates on inlets, PRES=0 on outlets. P=0 signifies atmospheric pressure.
Derrek Cooper
Message 7 of 9
markkolk
Thanks so far,
I will try it, and let you know if it worked.
greet
Mark
Message 8 of 9
derrek.cooper
Depending on how sensitive the info is, often if you post the *.cfz file, someone might be able to tak a quick look if you run into trouble
Derrek Cooper
Message 9 of 9
markkolk
Hi
I let the model solve, but in the end it does not go feather. If do a 100 iterations it stops at 99 and if i
do 300 iterations if I stop it at 299.
what can this be?
Best regards,
mark
