Discussion Groups
Simulation CFD
107 Kudos
Adaptive timesstepping
154 Views, 3 Replies
03-11-2013 08:24 AM
I am using adaptive timestepping. For some reason, after finishing the first scenario, the SimCFD is stuck on "Surface meshing... 193/241"
This doesn't happen with a simple pipe geometry. So it is not a generic issue.
How to tackle this?
OJ
Valued Contributor
34 Kudos
Re: Adaptive timesstepping
03-19-2013 03:55 AM in reply to: OmkarJ
I'd check face no. 193. This may not fit herre, but sometimes a visible sketch from the original Inventor geometry can cause surface meshing issues. If you go to outline view the sketch should be visible in CFD. Hide it in Inventor...
107 Kudos
03-19-2013 04:33 AM in reply to: marco.mueller
There is no visible sketch in Inventor model. I have realised that this is an indeterminate issue. Sometimes it happens, sometimes, it doesn't.
Product Support
149 Kudos
03-19-2013 03:36 PM in reply to: OmkarJ
I agree with Marco, identify that surface, does look like it could cause issues?
Jon Wilde
