CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
8 core machine uses only 4 cores
4 REPLIES 4
560 Views, 4 Replies
Lately, I added the 2nd processor that has 4 cores resulting in total 8 cores.
But, the solver still uses only four cores. What am I missing?
Thanks.
4 REPLIES 4
Dan_Margulius
Maybe your cores are multi threaded.
CFD only uses the physical cores.
Dan
I'm 100% positive that it's not multithreading. Again, I put two (identical) physical processors (each of them has 4 cores).
I have both CFD 2013 SP1 and CFD 2014 on my machine; interestingly enough, I can run both versions at the same time, say, one uses 4 cores, and the other uses another 4 cores. Any explanations?
Royce_adsk
You will probably need to run SimCFDConfig.exe at this time for the installation to update it settings.
When you do run this program run it with right click - 'run as administrator'.
Also, delete this file before you run the configuration program: C:\Program Files\Autodesk\Simulation CFD 2014\SystemInfo2014.xml
Let us know if that fixes the issue!
Royce.Abel
Technical Support Manager
It worked. Thanks, Royce.
