CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
2013 Simulation crash after open new file
3 REPLIES 3
winner117
767 Views, 3 Replies
I try to launch the simulation from both the add-in of inventor and right from the short cut, but every time the simulation trying to open a new analyse file, the software will crash....
I already disable the tablet..... thing, and reinstalled several times.
BTW I'm running on my Macbook by parallel.
3 REPLIES 3
in reply to: winner117
I think I might be having the same problem.  Inventor 2013 seems to work fine, but if I try to run Simulation 2013 (either from its tab within Inventor or directly), it crashes and the following message appears:
The instruction at 0x4008b571 referenced memory at 0xffffffff.  The memory could not be read.
Click on OK to terminate the program
Click on CANCEL to debug the program
Royce_adsk
You'll need to call into support so we can explore this with you.
Royce
Royce.Abel
Technical Support Manager
Actually the disabling tablet input thing fixed it for me.
