To make sure that my model is running with the correct parameters (ie. making sure I didn't accidently set the wrong unit type), I check max/min pressure for the system 10 iterations in. I'm guessing that most experienced users of CFD can judge if the simulation will be a waste of time based on max/min values for pressure and velocity.
Is it possible to have the simulation monitor report these values so I don't have to have Autodesk CFD open?
