Select Scenarios to Clone
When you clone a design with many scenario sometimes you don't want to clone everything.  The ability to select clone all or clone selected so we could pick which ones to clone would quicken the cloning process.  One example you wouldn't want to clone everything is when you are cloning after running a model that you saved cycles with adaptation.
5 Comments
sgold
Option to NOT clone the results would be much more efficient in many cases.
jreul
...and not clone the mesh.
ryan.arnaudin
Status changed to: Accepted
ryan.arnaudin
Status changed to: Solution Provided
Happy to announce that this is available in 2017!
You will be able to select which scenarios to clone with a design, and also whether to include mesh + results.
philip.s
