Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Inviscid flow
Inviscid flow
In the turbulence setting under the physics tab of the solve dialog, one can choose laminar or turbulent flow. How about adding a third inviscid option which automatically adjusts the flow setup appropriately (or perhaps a flag). I am aware that there is a way to manually simulate Euler flow.
2 Comments
kaikens
I have to agree. A straightforward option like this is standard in most commercial CFD applications. The present workaround (i.e., setting a low viscosity and applying slip conditions at walls) does not take advantage of the fact that the viscous terms need not be calculated in an inviscid simulation. It is inefficient and a bit clunky.
ryan.arnaudin
Status changed to: Accepted
