Show only
Search instead for
Import Inventor work points to be used as monitor points (Parker Hannifin)
User would like to be able to import work points from Inventor and define them as monitor points in Simulation CFD. This would prevent the user from having to type in coordinates for each monitor point.
To support that, one of the most important practices in experimental fluid mechanics, is to compare the results from the simulations with the one from the tests, which is also a very common practice, so usually we have a data about some exact points that we have their coordination, so it will be very important matter to import these coordination form a *.txt or *.csv file for example to the CFD
