Heat Flux and Heat Generation Summary Information
The following concepts were recently received from a customer interested in improved tracking of assigned heat flux and heat generation conditions:
  1. The boundary conditions for heat flux, heat generation should be capable of being named to describe what the particular BC is for.  So rather than have a non-descript term:  Total heat generation(xxx W)  I would like to edit it and say: Resistor R8 (xxx W)  or Transistor Q1 (xxxW).  It would make the model easier to check and edit as the BC would be more descript.
  2. The program should have a feature to check the total heat load going into the model prior to running the solution.  I know what the total heat load is and after assigning the heat flux or heat generation BC’s, I would like to make sure it totals what it should.
  3. The summary report/summary should contain this same information.
