Currently if you run a transient analysis and save muliple saved intervals, the parts calculator will give you data for each saved interval. The issue that users run into is that it is difficult to interperate the data since there is no time step recorded for each output. The enhancement would be add a line that informs the user what time step the data is from.
An example output is as followed:
I initialized the temperature of the part to -10C and was being warmed up to 0C over a transient analysis.
Part ID: 1 Name: CAD Volume_U_CAD Volume
Minimum coordinates of bounding box: ( -0.24114, 0.91535, -4.4296e-17)
Volume = 0.022831 in3
Minimum Temperature = -3.9096 Celsius at ( 0.0022248, 1.7126, 0)
Maximum Temperature = -0.757422 Celsius at ( 0.2352, 0.93749, -4.3216e-17)
Volume Averaged Temperature = -2.6766 Celsius
Minimum Temperature = -9.9449 Celsius at ( 0.0022248, 1.7126, 0)
Maximum Temperature = -5.796495 Celsius at ( 7.4657e-05, 0.91535, 0)
Volume Averaged Temperature = -8.9183 Celsius
Minimum Temperature = -9.3079 Celsius at ( 0.0022248, 1.7126, 0)
Maximum Temperature = -4.584766 Celsius at ( -0.23963, 0.94819, 0)
Volume Averaged Temperature = -7.6711 Celsius
Minimum Temperature = -8.6769 Celsius at ( 0.0022248, 1.7126, 0)
Maximum Temperature = -3.846139 Celsius at ( -0.23963, 0.94819, 0)
Volume Averaged Temperature = -6.8637 Celsius
