I imported a ProE part file to SimStudio and made some modifications, then I exported it in STEP format to autodesk CFD. After I set up the model, the model is not an entire body as before, instead, it is broken up into surfaces. However these surfaces are not displayed in SimStudio, so I cant select them and stitch them all up. I attached a screenshot of model browser tree. Anyone has any insights?
Cheers,
Gubing
Solved by tyler.henderson. Go to Solution.
Hi Gubing,
From the screenshot, it appears you have one surface body that contains 723 faces. Could you try unstitching the surface body, then restitching to convert it to a solid body?
Could you share the model if the suggestion doesn't work? We'll be happy to take a closer look.
Best regards,
You can try window-selecting the entire body for unstitch then re-stitch as Hugh mentioned.
Tyler Henderson
Principal User Experience Designer
