3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Voiding spherical characteristic from Environment Map
6 REPLIES 6
672 Views, 6 Replies
My rendering, shown below, keeps wrapping the image that I'm using for the Environment Map, creating a vortex-like appearance as the background.  I attempted to change this characteristic in the material window to "Screen" instead of "Spherical Object", but that has not changed anything.  Does anyone know how I could change this?  Any help would be very much appreciated.  Thank you.
P.S.  I'm new to the forum and I could not find any topic on this particular "issue", so sorry if this is a repeat.
6 REPLIES 6
Does no one know how to fix this issue?  That would surprise me.
Again, any help would be very much appreciated.  Thank you.
ekahennequet
Several questions: How did you setup the Environment Map? Was it via Environment dialog, or is it a Spherical object? Are you displaying the map in your viewport? Could you do a screen grab of showing the Viewport, Envrionment dialog, and Material Editor?
in reply to: ekahennequet
Thank you for replying.  I have attached the Environment Map with the Material Editor as well as the viewport.  Could the initial daylight settings be the reason this is happening?
PROH
Hi dfox19
Looking at "Environment Map.jpg" the problem could be quite simple. The map in the environment slot is not the same as the map in the material editor. They got different names.
Drag the map from the material editor to the environment slot, choose "Instanced", and render again. Does the problem persist?
Hope it helps
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
in reply to: PROH
Great catch, it worked!  Thank you very much assisting me; both of you, I really appreciate it.
I thought that I had done that before when I first had trouble with this a few months ago, but I guess there were other hidden issues that were eventually solved for that to finally work.  Again, thank you for the help!
ekahennequet
Glad you solved the problem. 🙂
