You can move uv's and stitch edges together to have a more perfect map. In most cases, you won't have a perfect uv map out of the box with one click, you will need some works, sometimes, hard work to achieve a perfect map.
Practices and good tutorials on this subject are important.
You could also try a plugin from an external source specialized in unwrapping, for example, Unwrella
