I have a 5 meter peice of road I have modeled for a project. Made a UV Map and Texture map for. I have also made a 10 meter road. I there a way to set up the 5 meter texture map I have already made so it simply tiles twice down the 10m road?
Rab
yes you type in a 2 in the tiling under the bitmap cordinates or you ad a UVW Map and change the Length cordinates to half the amount
You can tile it in Coordinates Rollout section after you've assigned a Bitmap.
Coordinates Rollout (2D)
If you're using the UVW Map modifier, you can also change the tiling from Modify panel.
UVW Map Modifier
