3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Scanline render issue ; multiple shadow recievers
1 REPLY 1
TobiRe96
629 Views, 1 Reply
Hey guys whats up ?
I have a problem with the good old scanline renderer.
At the moment I´m working on a project where I animate a "devil monster" , hunting a person under a bridge.
I render with scanline. The problem is that i´d like to rebuild this bridge in 3d in order to get most realistic light and shadow results. However as soon as I make more than one Matte/shadow object , they begin to cast shadows onto each other and everything looks horrible. How do I get rid of those grey boxes ?? (
Take a look at the pictures ( first is rendered only with the ground - everything is fine, second is the complete rebuild, third is the render of the complete rebuild  ) :
I hope you can help me
best regards
Tobi
1 REPLY 1
jeff
in reply to: TobiRe96
Instead of using matte/shadow on everything, what if you make the ground matte/shadow, and for the other meshes, use a standard grey material and set the Object Properties to not "visible to camera" (uncheck) -- they will still cast shadows on the ground, but should otherwise be invisible.
Max since 1992 (3d Studio) · Win 10-64 · Wintel workstation · 64 GB RAM · nVidia Quadro RTX 4000 · BB render garden via Deadline
