Hello experts ,
I've searched everywhere but couldn't find a clear answer for my question , So I've decided to come to the experts area looking for the answer. So I hope that you can help me .
My friend owns a design company ( uses Autocad , Photoshop and 3D max ) and asked me for a powerful machine for fast rendering only , not designing.
So , i kindly want to know what are the basic factors that speeds the rendering process ?
* # of CPU
* Speed of CPU
* CPUs L2 Cache
* # of Cores per CPU
* # of Threads per CPU
* Amount of RAM
* The use of SSD HDD over SATA
* Nvidia Tesla or Quadro Card ?
Appreciating your help.
Many Thanks
Hi. You need to tell us what renderer he'll be using. Is it a GPU renderer or a CPU renderer? If it's a GPU renderer it's mostly about the graphic card (how many Cuda cores and how much RAM on the graphic card). If it's a CPU renderer the main concerns are numbers of cores, processing speed and RAM amount.
For more detailed answers you need to be more specific.
Hope it helps
It is the render engine used that defines if it uses the GPU, CPU or both. That's why I'm asking for the specific choice of render engine 🙂
for example mental ray is cpu well as furry ball is gpu render or as a hybird the new amd fire render engine for 3dsmax is gpu and cpu combine you can fine this infomation out at the actualy render engine page for cpu render engines you would want to try to get the best cpu you can afford although cpu renders are much slower then gpu as for gpu renders get the best gpu you can afford and also dont forgot to get good quility ram i would recomend no less then 12 g specaily if you use maya and bifrost
Thanks All for your help.
I've visited my firend and saw that he's using VRay 3.02 and GForce .
So , kindly Advise me regarding the best hardware . I'm thinking of the below
• Dual Intel® Xeon® processor E5-2658 v2 (10 Cores, 2.4GHz, 20 M Cache)
• Single NVIDIA Quadro K6000
• Single NVIDIA Tesla K20C
• 64 GB ( 16 x 4 )ECC DDR3 1866 MHz
• SATA SSD 600GB ( Raid 1 )
• Windows 7 64-Bit
will this configuration conflict with VRay or will not be fully used by VRay ?
will it be better to use Dual NVIDIA Quadro K6000 .
I'm confused about what is the best GPU that works the best with VRay to have the minumu Rendering time .
Many Thanks
Rendering with V-Ray will not use the video card. So you could save a lot of money by not adding in the expensive GPUs.
We use V-Ray for all of our work, and have a render farm in our server room consisting of about 30 machines. None of them have graphics other than on-board. They render quite well without it.
Chris Medeck
As mentioned in VRay website that version 3.3 supports GPU Rendering .
https://www.vray.com/vray-for-3ds-max/buy-vray-for-3ds-max.html
Kindly advise before buying this expensive server .
thanks alot
Ah, sorry for the confusion. V-Ray can support GPU rendering when using V-Ray RT only. This is their real-time render engine. It does have a few limitations in regards to compatible materials and lighting, and in all honesty I've only ever used it to get immediate feedback while adjusting lighting in a scene.
If your friend is going to be using V-Ray RT as their renderer, then go ahead with adding the beefy graphics cards. But if it is strictly the vanilla V-Ray renderer being used, then a GPU is completely unnecessary.
Chris Medeck
