Good day guys,
I am facing a slight issue with Max 2011 rendering out a 500 frame animation. It renders out normally, no errors messages or whatever. Render settings like so:
However the output file only shows about half of my animation. How can I fix this please? I have already tried both "active time segment" and manual range.
Bill
Solved by Steve_Curley. Go to Solution.
Hello Steve,
Thank you for your advice. I rendered as png sequence and imported it into AE which then rendered a H.264 video. Entire process was quick and only involved remarkably small file sizes. Given you a thumbs up.
Cheerio,
Bill
Rendering to individual files is always the best option. Because it is not a matter of "If" your render will error out, but "when". Rendering individual frames allows you to resume redering where it left off using "skip existing images". I used to get frustrated all the time rendering to an AVI and have it error out at 98% only to have to start all over again. Not only that but if there are glitches in your renders, you can simply re-render the individual corrupt frames instead of having to process all 500 again.
