I have a little probleme with the render size in my render window. The size of me render is not the same as my settings says. This is both in Mental Ray and Maya Vector. Im using a student version of Maya 2014. How can I change this? 😕
Render output
Here are my settings.
Solved by bera_kuntal. Go to Solution.
U need to change render Percentage from Render View - Options Menu-Test Resolution...
I had the same trouble, even if I make an override and lock the size attribute for the size...nothing worked except this solution...on Maya 2018 is on Render-Test Resolution - Render Settings..... I suggest that if you are making an OVERRIDE FOR THE SIZE it stays in that size
