3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Render Consistent Colors
5 REPLIES 5
Thrasill
9484 Views, 5 Replies
How can I render my object with consistent colors just like I see it in the Viewport with consistent colors. I tried with the quicksilver renderer. The quicksilver renderer works fine with all the other visual styles except Consistent Colors and Clay. For these 2 it appears black. I have attached my object in a jpeg. It's just a low poly character. I only applied a standard blinn material. No other effects.
5 REPLIES 5
Thrasill
in reply to: Thrasill
I noticed something weird. So I render the Teapot with Daylight and a plane beneath it. In realistic it looks perfect. But when I rendered consistent, clay and hiddenline I noticed a weird behaviour. It renders only the plane in a weird position. Have a look on the attachements please.
PROH
Hi. Consistent means "flat" without materials and lightshading. Since your 2 objects are having the same color (not material), you can't see where the teapot is (consistent render). Using the same grey color also gives you a bad "hidden line" render. Try to give the 2 objects 2 different clear colors - like blue and red - and see how it works.
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
Thrasill
in reply to: PROH
Thanks for the reply. OK. So let me put it this way. Even if I create a box or a plane without applying anything on it, I just create a box and then render with Quicksilver with Consistent Colors style, still all I get is a black picture. I made sure the object is in the safe frame and I changed the colors, but all I get is black. I know consistent means flat. That's what I want to get: my character with the texture like it is in photoshop, and like it appears in the viewport when you have Consistent Colors on. No other shades or lights from 3ds max.
PROH
Hi. That's strange. If your viewport is OK, I don't know why Quicksilver won't work. One solution could be to use Spacefrog's "PowerPreview" script - it works fantastic. You can find it here: http://www.scriptspot.com/3ds-max/scripts/powerpreview-high-quality-nitrous-previews
Hope it helps.
3dsMax 4.2 to 2018
Thrasill
in reply to: PROH
Thank you. That script worked just fine.
