Hi Folks
I've been using the TIFF alpha channel to make part of the image translucent. Normally, it works fine. Occasionally, there are some artifacts caused by bleeding around the edges of the:
- object
- edges of the plane
Following some tips elsewhere, I have already tweaked the following settings in Max:
- turned tiling off
- turned premultiplied alpha off
- set diffuse, specular, ambient colors to black
- set specular level, glossiness to zero
Thanks for your help!
David
