I just got a new workstation with Max 2013 installed on it. I did a test render that i have from Boxx industries and it rendered out at about 6.2 times slower as the posted time from Boxx..
I noticed that the renderer listed was NVIDIA mental ray.. first time i had seen that. I have been using Max 2009 and 2012 for quite a few years.
So then i did a few googles and found a few posts where people were finding render times 5 or so times slower than they should be with Mental Ray?
Does anyone have any comments on this?
Q
Ok, i noticed that it only had update 4 installed so i downloaded update 6. Installed that and no change.
I tried rendering some other scenes.. Some of the ones that come with it like Troll Cleric 29 etc.. And have had a few crashes. It wont render that one actually.. I can render it on my old workstation in Max 2012 just fine.
Q
So I tested another machine. Same specs and it performs the same. Crashes on some standard shipped with scenes.
Is there a Benchmark scene that i could render to check speeds?
i wonder if maybe the Distribution package that this company uses is not good? Or not good for a higher end machine like i have?
They also set the computers up with preset software installs.. i wonder about that as well..
I am trying to find out if my company.. (huge) has some sort of service contract with Autodesk.
Q
No one will be able to help you unless you post something. Either the problematic scene itself, or screenshots of your render, material and lighting settings.
Yes this is true... But..
My basic questions are this:
Has anyone had similar MR slow renders?
Is there a Benchmark scene i could use to test?
Why would the Cleric standard scene crash two machines. Fresh installs/boot?
Unless someone asks for anything more specific i am not sure what else to say.
Q
I just opened the troll fella on my rig (see specs in sig) in 3ds max Design 2012, 2014 + 2015 and hit render.
The mental ray message window throws errors every time complaining about missing .dds files - probably because I messed around with the autodesk mat libraries which I don't use at all.
It renders fine though, taking 17s in max 2012 and 19s in 2014+2015.
Cool thanks..
Is there a better benchmark scene that is used by people?
I am trying to get the IT group to let me install my personal 2012 version on this workstation to see how that runs. I believe the 2013 custom corporate install is broken. And i can not load that Troll project at all.. even when i copy it from my old running fine workstation. It kills Max dead!
Q
Try to reset your user settings.
Try to merge the troll - or parts of him - into an empty drawing to find out what causes this.
I reset everything and that did not help anything.. I guess i could import it and see if i get anywhere but i dont really care about that file it was just one that came with it and it does not work along with others.. I am trying to figure out if there is something wrong with the install. I copied that file from my old workstation and it crashes as well. So its not the actual file.
My company signed me up onto the subscription but it seems that does not really help me. I thought there would be some kind of actual support associated with it but it is just the same search engine i have here i believe.
What i really want is an Autodesk person to help me troubleshoot this thing.
And i am so surprised that there is not an official benchmark scene and a list of render times.. very strange. The Boxx Tech benchmark scene runs fine but 6.2 times slower than what they post.. that worries me as well... their tech thought it was just that Max 2013 MR sucks... that seems extreme to be 6.2 times slower... i can see a small margine but that is too much.
Q
What you have access to in the Subscription site depends on the rights you are given. From what I remember the lowest level doesn't have sufficient rights to file a support request, just downloading the installers and subscription-only bonus content. There should be a means of filing a support request, with options for general questions, activation/licensing support, and so on. Normally the technical support questions are first forwarded to your reseller to get additional information. If they don't have an answer then it goes to an Autodesk support technician. If you can't get to filing a support request, recheck with your Subscription supervisor who should have full Contract Admin privileges to see about elevating your level and/or request help from inside the Subscription site.
Hello Qholmes-
I will be sending you a private message via this case number -10253779.
Jonathan Matthews
Autodesk Frontline Technical Support.
