]6/21/11 10:25:26 PM .com.autodesk.Maya.2012 MSG 0.0 info : adding new host 1 (10.0.1.100:7412)
6/21/11 10:25:26 PM .com.autodesk.Maya.2012 MSG 0.0 error 011330: mi-ray/tcp: not a service (check /etc/services)
6/21/11 10:25:26 PM .com.autodesk.Maya.2012 MSG 0.0 warn 012219: using fallback inet service 7003
6/21/11 10:25:26 PM .com.autodesk.Maya.2012 JOB 0.0 info : started threads 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15 on 10.0.1.100:7412 now known as host 1
6/21/11 10:25:26 PM .com.autodesk.Maya.2012 MSG 0.0 info : adding new host 2 (10.0.1.112:7412)
6/21/11 10:25:26 PM .com.autodesk.Maya.2012 MSG 1.0 info : version 3.9.1.43, May 10 2011, revision 148537
6/21/11 10:25:26 PM .com.autodesk.Maya.2012 MSG 0.0 warn 012217: bad response: 'The syntax of the command is incorrect.??' (41/512)
6/21/11 10:25:26 PM .com.autodesk.Maya.2012 MSG 0.0 warn 012218: check executable and version used on remote host:port 10.0.1.112:7412
6/21/11 10:25:26 PM .com.autodesk.Maya.2012 MSG 0.0 error 011321: read from host 2 failed: Connection reset by peer
6/21/11 10:25:26 PM .com.autodesk.Maya.2012 MSG 0.0 error 011213: cannot receive welcome message from host 2 (active)
6/21/11 10:25:26 PM .com.autodesk.Maya.2012 MSG 0.0 error 011706: cannot add host 10.0.1.112:7412
