Title says it all. When I look at my rendering options, Mental Ray is nowhere to be found. Used to be there. Now it isn't.
Still using my Maya2012 student version, but I do not see why that should be a problem.
Suggestions?
Different location, but yes, I do see that file.
Again, Mental Ray has been available before, so I do not know why it isn't available now.
Hi
Sometime Maya behave like that, Open new maya and and then go to your prefrences and check mentalRay is there or not , it will be named as "MayatoMr" . and then check in your render using software mental ray is there or not , may be it will work for you .
Thank you. I will have to add this to my list of "Stupid things that can happen in Maya for no good reason." Autodesk should put that FAQ together.
