I have a scene renders on 40 to 45 seconds per frame. When on network render the same scene takes 4 to 5 minutes per prame. The translation takes too long during network render (about 3 minutes per frame). when rendered from max directly translation is about 8 seconds.Is there any solution or work around for this issue.
Solved by snanook. Go to Solution.
Apperently it was a skinwrap issue.
solution was found in http://forums.autodesk.com/t5/Autodesk-3ds-Max-3ds-Max-Design/Skin-Wrap-issue-in-2013/m-p/4254584
