I have used the vray glass material to show the object "sculpture" thats inside but it's being so reflective , i want it to be transparent but not reflective
Thank you.
Solved by CAMedeck. Go to Solution.
What you're showing is a solid glass cube with something inside. I'm assuming you're more interested in having a glass box around the item, correct? Use a Shell modifier to give the sides of your box some thickness, so it isn't a solid cube but a box with an empty center where your sculpture is.
Chris Medeck
I have another problem About the Glass material , i have used the glass material but there is darker blue clour in the edges is that normal??I have attached you the picture so you get a better image
Is that image being rendered from a camera view, or just a User viewport? Anything with reflections or refraction will not render correctly from an Orthagonal view like the User view.
Chris Medeck
I have used User viewport , I still dont know how to use camera view since im still new at rendering but im glad to know why it wasn't working , my first step was to learn v-ray materials then the secound step i should learn is how to use a camera right?
Is there any steps to do while doing a camera?
If you don't feel ready to start in with Cameras, then I would recommend doing your test renders using a Perspective viewport rather than User. It will give you better results.
Chris Medeck
