3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Glass V-ray material issue
6 REPLIES 6
Riyona
673 Views, 6 Replies
I have used the vray glass material  to show the object "sculpture" thats inside but it's being so reflective , i want it to be transparent but not reflective
Thank you.
6 REPLIES 6
CAMedeck
in reply to: Riyona
What you're showing is a solid glass cube with something inside.  I'm assuming you're more interested in having a glass box around the item, correct?  Use a Shell modifier to give the sides of your box some thickness, so it isn't a solid cube but a box with an empty center where your sculpture is.
Chris Medeck
Riyona
in reply to: CAMedeck
Thank youuuuuuuuuuuu , You're a Geniussssss!!!! It worked
Riyona
in reply to: Riyona
I have another problem About the Glass material , i have used the glass material  but  there is darker blue clour in the edges is that normal??I have attached you the picture so you get a better image
CAMedeck
in reply to: Riyona
Is that image being rendered from a camera view, or just a User viewport?  Anything with reflections or refraction will not render correctly from an Orthagonal view like the User view.
Chris Medeck
Riyona
I have used User viewport , I still dont know how to use camera view since im still new at rendering but im glad to know why it wasn't working , my first step was to learn v-ray materials then the secound step i should learn is how to use a camera right?
Is there any steps to do while doing a camera?
CAMedeck
in reply to: Riyona
If you don't feel ready to start in with Cameras, then I would recommend doing your test renders using a Perspective viewport rather than User.  It will give you better results.
Chris Medeck
