Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Error when I render in Maya.
4 REPLIES 4
2509 Views, 4 Replies
I get this when I go to render then change material.
createAndAssignShader blinn "";
connectAttr -f blinn19.outColor blinn19SG.surfaceShader;
// Result: Connected blinn19.outColor to blinn19SG.surfaceShader. //
// Error: file: /Applications/Autodesk/maya2013/Maya.app/Contents/scripts/startup/createAndAssignShader.mel line 153: No renderable object is selected for assignment //
// Created shader blinn and assigned to the selected objects. //
// Error: file: /Applications/Autodesk/maya2013/Maya.app/Contents/scripts/others/updateAE.mel line 504: Cannot find procedure "AEsetDisplayToEmpty". //
// Error: file: /Applications/Autodesk/maya2013/Maya.app/Contents/scripts/others/updateAE.mel line 527: Cannot find procedure "AEsetDisplayToNodes". //
I'm using a MacBook Pro.
4 REPLIES 4
Have you installed Service Pack 2?
Doing that now. Just figured out what you are talking about. Hopefully it fixes it.
That did not fix the issues. I'm a little pissed because you spend a lot of money on a program and yet you can't even get customer service to help you because they want you to pay for that. I have sp2 installed and the issue is not fixed I found another sp2 DMM which didn't fix this issue either.
