Maya 2017 - Haven't had to do this in awhile... but how do I display an objects transform data in the hypershade when graphing it?
By default, I only see shader details...
A bit detailed version:
In Hypershade:
Hold Right Mouse BUtton->Show->Show All in the work area.
Select the object and click the Input and output connections button in Hypershade.
If you Shift+Select the material as well you can see all the nodes are related.
Cheers, D
