3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Diffuse map not showing on complex objects?
2 REPLIES 2
SFKislev
1457 Views, 2 Replies
Hi!
this is my first post and and i'm a noob, so this might be something simple i've overlooked. I've imported a mesh from zbrush (exported as obj) and tried to apply a material to it, but the disffuse, bump and displace maps of the material seem to refuse being applied. When I try the same material on a simple sphere created within max there's no problem. See attachments: same material, same light settings.
I'd really appreciate your sugesstions!
Thank you
F
2 REPLIES 2
Brock_Lafond
in reply to: SFKislev
What is the map resolution?
To me it looks like the res is too low for the object. If the texture is tileable, try tiling it.
Alias/Wavefront Maya 3 -> Discreet 3DS Max 4 -> ...
Win7 Pro 64
EVGA Classified Super Record 2
Dual Xeon Hexa-Core, 48GB RAM
GTX 780 x 2
Corona Renderer, mental Ray
CAMedeck
in reply to: Brock_Lafond
Your images are pretty dark and hard to see, but I'm guessing the UVW mapping is not set up correctly.  Are you using Real World Coordinates?  Can you preview the material in the viewport, and does it look correct there?
Chris Medeck
