3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Crazy ior!
11 REPLIES 11
Message 1 of 12
3d-Soul
683 Views, 11 Replies
Crazy ior!
I'm working on an exterior night scene and have a confusing issue that I've never had until now.
my workflow is that I first put some vraylight inside the building and then start to set-up extrior lights. I have
a big single object for the windows' glasses so I could exclude it from material override, but as you can see in
the attachment I have a odd refraction/reflection in my windows with ior value of 1.6 that always I use. I tested
some other values (1.3,1.1,...) to find the answer but finally I was forced to hide window object to prevent from
probable unwanted issues!
any help on this problem would be appreciated. thank you.
BTW I'm using vray 2.4.03 and 3ds max 2013.
______________________________________________________
2*Intel® Xeon® Processor E5-2697 v3 (35M Cache, 2.60 GHz)
32 Gb Ram DDR4 2133
GeForce RTX 3060
Windows 10 64-bit SP1.
3ds Max 2020 64-bit
http://www.3d-soul.net
Mohsen.K.
11 REPLIES 11
Message 2 of 12
CAMedeck
in reply to: 3d-Soul
Is your window object using the correct thickness for the glass?  I've seen where planar glass objects do something similar.  Adding a Shell modifier set to a half inch or so corrects that.
Chris Medeck
Message 3 of 12
3d-Soul
in reply to: CAMedeck
Yeah, I always do real scale modeling. The glass object have 0.6cm thickness. there's no overlapped faces.
today I have some extra times, maybe find the answer but don't deprive me of your comments.
32 Gb Ram DDR4 2133
GeForce RTX 3060
3ds Max 2020 64-bit
Mohsen.K.
Message 4 of 12
3d-Soul
Didn't find any solution. maybe it's a vray bug or something.
I did a few test renders with iray, mental ray, vray RT and it looks good in iray and mental ray.
the attached zip files includes renders and the glass object if you want to give that a try.
32 Gb Ram DDR4 2133
GeForce RTX 3060
3ds Max 2020 64-bit
Mohsen.K.
Message 5 of 12
3d-Soul
don't know why but I can't see my last post. my post counts are rising but I can't see them.
Edit : it should be related to the attached files because I can see this post right now.
32 Gb Ram DDR4 2133
GeForce RTX 3060
3ds Max 2020 64-bit
Mohsen.K.
Message 6 of 12
Steve_Curley
Which one(s) can't you see? There are 4 posts in this thread (before I posted this one), 1 from camedeck and 3 from yourself. If I check your latest posts the 3 most recent are the 3 in this thread.
If you're convinced there should be more then a post in the Website Support Forum might be appropriate.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 7 of 12
3d-Soul
in reply to: Steve_Curley
Yes Steve, there are 2 or 3 more posts (although all of them should be similar because I couldn't see my post and had to repost it).
OK, I'll post there. thanks.
32 Gb Ram DDR4 2133
GeForce RTX 3060
3ds Max 2020 64-bit
Mohsen.K.
Message 8 of 12
3d-Soul
just for testing my post visibility !
I attached other renderer results and my glass object here if you want to give that a try.
Edit :
Funny ! it worked! anyway... Didn't find any solution. maybe it's a vray bug or something.
32 Gb Ram DDR4 2133
GeForce RTX 3060
3ds Max 2020 64-bit
Mohsen.K.
Message 9 of 12
Stefan_L
I know a similar effect, caused by Cutoff Threshold values reater than 0.00 in Arch & Design material, Advanced Rendering Options group. It basically ignores those phenomena below the threshold which leads to circular borders between a little and nothing.
Stefan
i7-2600 @ 3,4GHz, 32GB Ram,
512+128GB SSDs + 2x500GB HD
GeForce GTX 980 Ti 6GB + GTX 980 4GB
latest Driver (almost always)
Win7ProX64 SP1
Message 10 of 12
3d-Soul
in reply to: Stefan_L
thanks Stefan for comment.
turning "Reflect on back side" option on (VRayMtl Option rollout) improved the result but I think there's still a difference in darkness between left and right side. see the attached GIF file please.
32 Gb Ram DDR4 2133
GeForce RTX 3060
3ds Max 2020 64-bit
Mohsen.K.
Message 11 of 12
Stefan_L
I don't know anything about VRay, so I'm not much of a help there and won't dare to suggest:
"Use mental ray or iRay then, it renders fine." 🙂
Does rendering a perspective view instead of a camera (or vice versa) change anything?
Are the face normals correct?
Does it happen with a box + shell modifier too?
Is it caused by reflection or by refraction (or both)? Try a mirror material...
Stefan
Win7ProX64 SP1
Message 12 of 12
3d-Soul
Thanks stefan. I'm also a mr and iray user, but IMHO vray is simpler to setup, specially in interior cases. Yes, I've already checked whole your guesses. About your third question the answer is Yes, provided that I have several copy of these objects (something similar the above attached object). For last question, I think it's related to both, reflection and refraction. Anyway I completed the project and sent it to my client. They will have cold nights! I just wanted to know the solution and any more answers would be appreciated.
32 Gb Ram DDR4 2133
GeForce RTX 3060
3ds Max 2020 64-bit
Mohsen.K.
